Hello Olarila,
I would like to use LegacyAGPM.
I have edit the info.plist (Highlighted with Red Color) as below:
CFBundleDevelopmentRegion
English
CFBundleIdentifier
com.apple.driver.LegacyAGPM
CFBundleInfoDictionaryVersion
6.0
CFBundleName
LegacyAGPM
CFBundlePackageType
KEXT
CFBundleSignature
CFBundleVersion
100.12.42
IOKitPersonalities
AGPM
CFBundleIdentifier
com.apple.driver.AGPM
IOClass
AGPMController
IONameMatch
AGPMEnabler
IOProviderClass
IOPlatformPluginDevice
MacPro4,1
LogControl
0
Vendor10deDevice1201
Heuristic
ID
0
IdleInterval
100
TargetCount
5
Threshold_High
57
70
88
100
Threshold_Low
0
68
75
95
control-id
17
OSBundleLibraries
com.apple.iokit.IOGraphicsFamily
1.1
com.apple.iokit.IOPCIFamily
1.0
com.apple.kpi.iokit
8.3.1
com.apple.kpi.libkern
8.3.1
com.apple.kpi.mach
8.3.1
OSBundleRequired
Local-Root
Could you please check those edit is oki for my GPU GTX 560?
Do i need to change anything in SMBIOS? My SMBIOS info.plist as below:<?xml version="1.0" encoding="UTF-8"?>
SMfamily
MacPro
SMproductname
MacPro4,1
SMboardproduct
Mac-F221BEC8
SMserial
G89266254PC
SMbiosversion
multishit.tonycrapx86.com
Thanks in advanced...Thanks a lot :)
Just test it. Post "OpenGL Extensions Viewer" test results, with and without LegacyAGPM.
Sure Bro i would like to Test it. But i have been searching OpenGL Extension Viewer for Mac version but could not able to find out any of them. Could you please help me where i can find it or any download link, so i can go further.
Big Big Thanks!
One step at a time. Solve your App Store problem first, then you test OpenGL.
OpenGL Extentions Viewer 4.0
Test: Without LagecyAGPM (Full Screen)
1.1-2.1 Compatibility (OpenCL Profile) average 550
3.1-3.2 Core (OpenCL Profile) 249
3.3-4.1 Core (OpenCL Profile) Failed
Test: LagecyAGPM (Full Screen)
1.1-2.1 Compatibility (OpenCL Profile) 4231 4261 4173 4106 4104 4087 4088
3.1-3.2 Core (OpenCL Profile) 533 570
Why 3.3-4.1 Core result is Failed? Could you please tell me why this happened in both cases and how to fix this.
Rest result is OK or need further changes in LegacyAGPM Kext. Thanks for all your support :)
It looks fine.
This is normal.
BTW, it's OpenGL, not OpenCL.
It looks fine.
This is normal.
Opps..Sorry It's OpenGL :) Could you please tell me what is the reason for getting failed error for 3.3-4.1 Core.
Full screen and normal screen results are difference, normal screen av. 275 fullscreen 4000+??
No, I can't, but I'm sure you could find something using Google.
http://lmgtfy.com/?q=does%20Mac%20OS%20support%20OpenGL%203.3%20specs?
I don't have an opinion, it's not a subjective question. You have to compare with results from other people with similar hardware.
Example
http://www.insanelymac.com/forum/index.php?showtopic=276944&view=findpost&p=1804846
