[HELP] Nvidia GTX 760 Dual Display
Hello friends,
It seems that the GTX 760 does not give me an image through the HDMI in OSX Catalina.
Should something special be done in the clover or opencore config?
It is to have multiple displays connected to the graphics card.
what mobo u have?
have a csm option?
this patch is for internal graphics only
6 hours ago, cachiputi said:
im talking about this patch
Hi @MaLd0n
Yes, I know, maybe I didn't get the question right.
I was referring to which is the path where I should copy this file that you have created?
By the way, I suppose you have noticed that this CPU its integrated graphics is the 530, I think. As in the capture that happens to you, the 630 comes out.
Obrigado.
no idea bro
i never use this card
