Just click on "fix errors".
The errors are not in the txt, but in your original DSDT. They are considered errors in recent versions of IASL, which use new ACPI specs. If you use old version of IASL, it won't complain about those as errors.
ok, then clicking on Fix for error IASL I will have 'a good dsdt?
Another answer...but txt is generic for asus p8z68 deluxe or i need another patch?
Sorry but i want unterstound this fantastic job
:mrgreen::mrgreen: Without PC :mrgreen::mrgreen:
Clicking fix errors you'll have a correct DSDT according to new ACPI specs.
If you use patched AppleHDA you need to add HDEF patch in DSDT or use HDAEnabler kext.
Maybe there is not patch hdef for my chip in dsdt ...i have alc889
It depends on LayoutID used in AppleHDA
If you use patched AppleHDA you may need to update the HDEF patch according to your audio codec. Make sure layout-id in DSDT (hex) coincides with LayoutID in AppleHDA (decimal)
[table=400][trf][tdf]LayoutID (dec)[/tdf]
[tdl]layout-id (hex)[/tdl][/trf]
[tr][tdf]12[/tdf]
[tdl]0x0C, 0x00, 0x00, 0x00 = 0xC[/tdl][/tr]
[trl][tdf]889[/tdf]
[tdl]0x79, 0x03, 0x00, 0x00 = 0x379[/tdl][/trl][/table]
http://Olarila.com/forum/viewtopic.php?f=19&t=385
No, look in patched AppleHDA.
Layout id htlm ?
What are you talking about? That's nonsense.
:mrgreen:
Cassio sorry .
If i dont want fix in dsdt hdef....wich kext i need for my alc889 ... I have try hdaenabler 889 ...but dont work.
Only with iniecton in dstd work....why?
There's no difference, HDAEnabler and HDEF patch in DSDT, both do the same. Your problem is probably in AppleHDA patch.
Can attached my applehda patched and hdaenabler?
I do not want to use HDEF in dsdt but only a good applehda if I remove the dsdt HDEF my audio does not work, even if I put hdaenabler889.kext applehda and original from 10.7.3.
Unterstound....only for curiosity...only ;)
Patched AppleHDA is always needed, it won't work with original one.
You can choose between HDEF patch in DSDT or HDAEnabler.
Understood?
Option 1) patched AppleHDA + HDEF patch in DSDT
Option 2) patched AppleHDA + HDAEnabler
Understood?
ok ok thz now unterstound
