Help!!
Thanks to you I successfully installed it on:
MB: Gigabyte B460M Aourus Elite
Procesor: Intel Core i5 10400, 10th Generation 2.90Ghz
GPU: Intel UHD 630
RAM: 2x8 2666Mhz DDR4
Everything is working fine, except:
Sleep
HDMI (it works if I unplug and plug back the cable) (Sounds work fine)
USB-C (not sure, I haven't test it)
Thank you in advance
My Sendme File
https://mega.nz/file/WpsmECSQ#Du7tVfr3WAzjfqj_RJ0gRT0ps2MOKlO8eq6r9P2R4-8
Edited by pedropujols
TEST agdpmod=vit9696 or agdpmod=pikera
