HP Pavilion 15 macOS Big Sur 11.2 OC 0.6.7 Battery Drain
So after a lot of painstaking process fo following the guides, I'm able to create a working Hackintosh with almost everything working!!!
Unfortunately, I'm not able to fix the battery drain. The battery lasts for 1 hour or so. Can someone please help me. If I'm able to fix the battery drain, I will be able to fully transition from Windows to macOS.
My system is:
Intel Core i7-9750H, 16GB RAM
Intel UHD 630 + GTX 1650 (Disabled)
This is the link of log from RunMe.app https://drive.google.com/file/d/1omH95FTibHK3P3NKlUMoioChDlbzLk-E/view?usp=sharing
Please find attached my EFI. Thanks!
P.S: I omitted Kexts and Resources folder to comply with the size requirement. Kindly have a look at config.plist to find this information.
EFI.zip
Edited by Raffay
Added log
