Battery and Wi-Fi Issues - Acer Aspire V15 V3574G-53WB
Hello everybody, i hope you are all well! :wave:
I finally installed Catalina on my Acer Aspire V15 V3574G-53WB.
At the moment graphics and audio are working well!
The touchpad is working but is not reconaised becouse of the battery issue.
But when i tryed to make the battery status working i get some problems.
May someone help me to figure it out what is wrong with the battery? :banghead:
How you can see in this picture, the one on the left is the wifi card installed, the other one on the right is from another old leptop, and that type of wifi card dont fit in.
Can you suggest me a good wifi card that is compatible whit my PC?
If needed i'll post my efi folder and the ioreg.
Thanks in advance! :headbang:
6 hours ago, MaLd0n said:
Hello MaLd0n, thank you a lot for your answer. ?
If there is something else i can do, i'd like to help you investigating about the problem. ?
If possible i'd like to understand where is the problem just to know for future issue may i encounter.
take care! ?
i need check files
11 hours ago, MaLd0n said:
i need check files
Finally thanks to @MaLd0n now the battery and the trackpad is working perfectly!!! :headbang:
Here there is the magic DSDT.aml!! ? (working just for my laptop model - Acer Aspire v3-574g-53wb)
Now if you got time to explain how you solved the problem will be amazing!! ?
The last few things i have to manage are:
-Sleeping fix
-Change the Wi-Fi Card
And i think we have finished all the work for this new Hackintosh!! ?
Yo guys, i think is the last (i hope it is) problem with my new Hackintosh!! Anyone have a good suggestion for me about the wifi card? :D
Thanks! ?
