Hi, I'm new in Hackintosh and I would like to install Catalina OS.
My hardware is:
CPU: Xeon E5-2678 V3
GPU: Radeon RX 5500 XT
RAM: 16GB 2666MHz
WiFi Card: Fenvi FV-HB1200
What is the easy and recomended method for make it?
I have that folder yet, but my problem is that i can't install the MacOS system and therefore I can't do post-install EFI folder sterps.
I try to install clover but I thinks it's easy to install.
Thanks!
Edited by trujillo25
