In the file you attached it's inside PEX4.
The patch should be like this to work in your DSDT (or adjust the address)
into device name_adr 0x001C0004 insert
begin
Device (ARPT)\n
{\n
   Name (_ADR, 0x00)\n
   {\n
       Store (Package (0x0C)\n
           {\n
               "AAPL,slot-name", \n
               Buffer (0x08)\n
               {\n
                   "AirPort"\n
               }, \n
               "device-id", \n
               Unicode ("*"), \n
               "device_type", \n
               Buffer (0x08)\n
               {\n
                   "AirPort"\n
               }, \n
               "model", \n
               Buffer (0x34)\n
               {\n
                   "Atheros 9285 8802.11 b/g/n Wireless Network Adapter"\n
               }, \n
               "subsystem-id", \n
               Buffer (0x04)\n
               {\n
                   0x8F, 0x00, 0x00, 0x00\n
               }, \n
               "subsystem-vendor-id", \n
               Buffer (0x04)\n
               {\n
                   0x6B, 0x10, 0x00, 0x00\n
               }\n
           }, Local0)\n
       Return (Local0)\n
   }\n
end
Ok, address is the same (0x001C0004) so the patch in previous post should work. I think I won't add it in the full patch since it's not the default wifi.
It works if you change the address, it's not the same for all boards, so we can't have a generic patch that will work for all.
into_all all code_regex Name\s\(_HID,\s"ABCDEFGH"\) replace_matched
begin
Name (_HID, "11259375")
end
Why change it to decimal? The error is about non-hex digits, so "ABCDEFFF" or same value from _CID also avoids the error.
I mean using the same value as _CID ("PNP0C15").
Actually I don't think it will make any difference.
