my laptop's battery would drain at a much faster rate after DSDT patch done by the moderator.
shutdown doesn't work
these are the 2 issues i've been facing, please help me.
my laptop's battery would drain a lot while in sleep mode, which wasn't the case before. the battery drop 5% every 10 mins in sleep mode now.
the dsdt was patched before to fix wake from lid down issue and to fix touchscreen.
attaching necessary files.
patched dsdt, runme.app generated files and config.plist
Send me Pushpaks-MacBook-Pro.zip config.plist.zip DSDT.aml.zip
