RX 480 - GPU Fan reaches to max speed and not comeback to lower speed.
Dear @MaLd0n
After running a game, my RX 480 - GPU Fan reaches to max speed and not comeback to lower speed until I restart the machine.
My system is: Gigabyte B460M AORUS Pro - i5 10600 - Running at 11.1 Big Sur.
WIth the Asus RX480 4Gb
So do you have any idea or solution to resolve this issue?
P/S: I had tried to use AGPMInjector but it doesn't work at all. Also try to disable & enable iGPU in BIOS and no work.
no idea what happens
check if others users have same problems and solution
