Big Sur OpenCore 6.6 install stuck black screen - z490 aurus ultra wifi I9-10850k rtx3070(wegnoegpu) fenvi t919 crucial p2 in fractal meshify 2 case
Edit : SUCCESS
Framebuffer properties needed to be fully specified ( many many lines , will post later on)
thanks to @MaLd0n for his hand , and to Riski from indonesia
hey guys (@MaLd0n sorry if posted in the wrong place ) at this point I wouldn't mind a hand ?
im stuck at install with Big Sur ( install media made via Xps9370 hack on Catalina via dortania guide and comet lake tweaks and sets ) (( hack is for now windows on a cs3030 AND a pcie4 sn850 )
ive also tried similar config efi and got the same results .. none
DSDT , plist and all are good an sanity checked im liking my efi and plist and all .. )
used wegnoegp boot arg to disable rtx and also tried with custom made ssdt gpu disable non works
tried so many tweaks I can't remember but can include debugs
basically all my debugs end up by that on a black screen ..
tried usb2 port , usb 3port ..
at this point im starting to think the usb drive I use is faulty ? Kingston data traveler ( for some magic reason my hack worked on the Xps with another one , a lexar I try to keep intact in case .)
29:485 00:625 OCI4: Matching override 71F4B187 with 71F4B187 - success
29:523 00:038 AAPL: #[EB|SB:MKRN]
29:568 00:045 AAPL: #[EB.LD.LKFS|-?] Ok(0)
29:606 00:037 AAPL: #[EB.LD.LKC|-?] Ok(0)
29:645 00:038 AAPL: #[EB|FWFM] 0x00000000FFDFFF7F
29:684 00:038 AAPL: #[EB|FWFT] 0x00000000FD8FF576
29:722 00:038 AAPL: #[EB|BST:REV1]
29:812 00:090 AAPL: #[EB|CSR:OUT] 0x00000040
29:851 00:039 AAPL: #[EB.BST.FBS|+]
29:891 00:039 AAPL: #[EB.BST.FBS|ADSZ] 0
29:930 00:038 AAPL: #[EB.BST.FBS|KSSZ] 0
29:969 00:039 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
30:007 00:038 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
30:047 00:039 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m">
30:085 00:038 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
30:124 00:038 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
30:163 00:038 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
30:201 00:038 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
30:238 00:037 OCSMC: SmcReadValue Key 4D535463 Size 1
30:276 00:038 OCSMC: SmcReadValue Key 4D534163 Size 2
30:315 00:038 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
30:354 00:038 AAPL: #[EB|LOG:DT] 2021-02-15T23:47:11
30:392 00:038 AAPL: #[EB|LOG:EXITBS:START] 2021-02-15T23:47:11
dossier sans titre 2.zip
Edited by bichedeflex
sorry to bother you again my good sire @MaLd0n but i get the same errors could i bother you with a look at my efi ? what am i missing ( nvmefix doesnt do , taking out the 3070 out neither , i did format the ssd to gpt ,and also have one plugged that is not initialised yet
bios settings are good , however certain settings arent available to choose from on my aurus ultra ( like serial io )
bios/uefi config
cfg lock disable and csm disable
only it
thx i managed to lock my MB tweaking : error 69  , nearly got it , but managed to get it back on tracks with cmos clear ..
trying your efi base ( and all tweaking required for my efi compiling and all , and will get back , cheers
( altho still trouble with mb hdmi out and dp 3070 out being solely recognized by bios ..
