Hello Friends,
I am using Gigabyte G1. Sniper M3 Mobo which is having Creative CA0132 chip and Intel® 82579V Gigabit LAN Controller.
Did anyone manage to install this AUDIO and LAN driver in OS X Lion?
Please let me know and thanks in advance.
For LAN try AppleIntelE1000e.kext (you may need to insert your card ID in Info.plist)
http://sourceforge.net/projects/osx86drivers/files/Kext/Snow_Lion/
Audio http://Olarila.com/forum/viewtopic.php?f=18&t=454
Stupid Question :) Should i use Kext Utility to install, or i ll do manually in system extension folder. Bro how to insert card id in info.plist???
Thanks bro u are a true helpful hand. I swear :) thanks u so much...!!!
Use Kext Utility and install in /S/L/E.
Look device ID http://Olarila.com/forum/viewtopic.php?f=18&t=63
If it's not already there, insert in IOPCIMatch under 82579 http://Olarila.com/forum/viewtopic.php?f=18&t=1704
The Audio solution you provided isn't is for an external PCI Sound card?
No, it's not.
