Req : DSDT for Asrock Z68 Extreme 4 with Bios 2.20 (or help)
Remember to plug in the short sound cable directlty onto your motherboard not the longer one for sound. Then you only need the 892 dst and dst free kext. I extracted dsdt and then used _HID suffix must be all hex digits (GH) then pathed Generic (BIOS 2.20) it left me with 0 error's and one warning 3207 Warning ResourceTag larger than Field (Tag: 64 bits, Field: 32 bits) this was changed by changing a letter from D to Q i believe: For fix it needs CreateDWordField(this is field 32 bits) rename to CreateQWordField (this is field 64bit).
It worked but only with -x (32 bits). Perhaps I should have also used the Z68 ex4 standard bios. So I also installed tonycrap Easybeast. Now its working and Mac also has the dsdt so its vanilla, sort off. Without -x that is.
I didnt use internal Lan since kext were for lion just bought Presto / GE1000LA-E small ethernet card which works out of the box.
http://legacy.tonycrapx86.com/wiki/index.php/Network_Card_Database
Since its working don't want to install Java (not safe anymore) again to create DSDT but if you could answer if Z68 should be also applied very much appreciated. And thanks for the help. Took me a month but app store and Istore all working and updates as well and boots in 64bit. Afterwards you could say it should have been done in a day: lol. Sleepsetting I dont need.
