x79 Asus Rampage IV Extreme and OpenCore low GeekBench
Hi,
I'm having problem with my build made with:
  • Asus Rampage IV Extreme
  • Intel Xeon E5-2680v2
  • 48 GB RAM
  • Radeon RX 480
I installed BigSur and even update to the last versione (11.2.1) but there are two problems i figured out:
  1. I didn't manage to get USB 3 port to work, both the front ones and the MOBOs.
  2. Geekbench score is really slow (about 600/700 in single core and 6000/6500 in multi), while Cinebench gives me good scores.
My RunMe file is more than 3 GB so I can't drag it.
Thank you in advance,
RN
1- ur usb 3 is not intel. u need one "extra kext" for that
2- if u use a geekbench 5, not a bad score
