kathir Posted February 11, 2021 Share Posted February 11, 2021 HI, Thanks for the Community support. I could able to install Bigsur .... Really working well. (MB: Z390i Aorus Pro Wifi) I am facing issue in BT (BCM94360CS2), Wifi working. HS12 (F_USB Header) - seems not able to see. (USB mapping done correct I assume) another issue - Audio out -> Internal Speaker selected -> every boot -> it goes to Line Out. Appreciate with your help... Sendme file link below.. https://drive.google.com/file/d/1SdakrAcYK-JP36ON2IHXuC1VMffz97UR/view?usp=sharing Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 12, 2021 Administrators Share Posted February 12, 2021 if u have a intel card in mobo need disable port with Intel Bluetooth. common is hs14 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
kathir Posted February 12, 2021 Author Share Posted February 12, 2021 Thank you MaLd0n... Let me check it for HS14. Can you help me with Audio outputs?? Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 12, 2021 Administrators Share Posted February 12, 2021 https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
kathir Posted February 12, 2021 Author Share Posted February 12, 2021 15 hours ago, MaLd0n said: if u have a intel card in mobo need disable port with Intel Bluetooth. common is hs14 I have tried with disable... still no success... any advice plz..... Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted February 12, 2021 Administrators Share Posted February 12, 2021 post one ioreg https://olarila.com/files/Utils/IORegistryExplorer.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
kathir Posted March 7, 2021 Author Share Posted March 7, 2021 Hi, MaLd0N, I have tried yesterday night with USB Mapping. BT was working until today morning. Suddenly disappeared. I am using BCM94360CS2 with adapter connected SSD slot , wifi working fine. https://drive.google.com/file/d/17C_OAy729gGW7JxtddYeHpOXtNFvauyy/view?usp=sharing photos as attachment. Appreciate with your support... Archive.zip Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted March 7, 2021 Administrators Share Posted March 7, 2021 this bt is native check usb bt cable -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
