Que tal Maldo. Le comento tengo problemas con gráfica ice lake. 10 generación I3-1005G1, no logra hacerlo andar. Aporto datos del hardware. Creo que solo falta por funcionar la gráfica. Thunderbolt 3 tampoco va.
https://www.amazon.com/CHUWI-CoreBox-Pro-i3-1005G1-Expandable/dp/B08MT2ZCFK
Adjunto Efi. Para dsdt. O alguna solución. Desde ya gracias.
https://1drv.ms/u/s!AqrrLpD_98fshQg51bEILbKSXZH1
Edited by ovacai
você não tem nenhum dispositivo declarado nas propriedades do dispositivo congfig.plist  deviceproperties
Quote
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AQAAAA==</data>
                <data>AQBcig==</data>
                <key>device-id</key>
                <data>XIoAAA==</data>
                <key>enable-cdclk-frequency-fix</key>
                <key>enable-cfl-backlight-fix</key>
                <key>enable-dvmt-calc-fix</key>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AAAwAQ==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AAAAwA==</data>
            </dict>
Hi, I'm from Italy.
I've no experience with Hackintosh, and i've found this thread because i've got a Chuwi Corebox Pro too.
Osx starts very well, but i can't find the correct combination of data to activate the HW Acceleration.
I used the Ovacai's EFI folder, because i can't make it myself :)
Any idea how to solve this problem?
https://drive.google.com/file/d/1kz-TuP5JfC_zSltYf5Tw7x-jJYgNENad/view?usp=sharing
https://drive.google.com/file/d/1UaMJjeloTGKkTe0eiVasIsS4A1wfRmNv/view?usp=sharing
Here it is
Edit: Reading on various sites, i've found how extract from BIOS this:
0x2FCB1     Setting: DVMT Pre-Allocated, Variable: 0xA4 {05 91 C9 05 DF 05 41 27 18 00 A4 00 14 10 00 FE 00}
0x2FCC2         Default: 8 Bit, Value: 0xFE {5B 06 00 00 00 FE}
0x2FCC8         Option: 0M, Value: 0x0 {09 07 CA 05 00 00 00}
0x2FCCF         Option: 32M, Value: 0x1 {09 07 CB 05 00 00 01}
0x2FCD6         Option: 64M, Value: 0x2 {09 07 CC 05 00 00 02}
0x2FCDD         Option: 96M, Value: 0x3 {09 07 CD 05 00 00 03}
0x2FCE4         Option: 128M, Value: 0x4 {09 07 CE 05 00 00 04}
0x2FCEB         Option: 160M, Value: 0x5 {09 07 CF 05 00 00 05}
With uefi shell  i've checked that this bios is at 0x0, 0M, but i can't change this value due for a probably locked bios.
Edited by Cupidz
Sorry MaLd0n, but i think i've not understand very well.
If i use my 1005G1 without acceleration the HDMI out is ok.
If i try acceleration i need to try DP o type-C?
My Chuwi has 1 HDMI, 1 DP,1 type-C (now i've connected to a hub with HDMI output and other usb)
Thank you very much
Edited by Cupidz
