Hello guys, I would like your help, I'm having some problems after installing Big Sur, in the color of the screen and the WI-FI connection. The screen is an LG 27uk500-w and the problem is that it is extremely saturated and with less adjustments than normal, as for the internet I've a Fenvi T919 / MB Gigabyte Z490 Gaming the internet is super unstable, I have tested it on all devices and only on hackintosh I have the problem. I tried several adjustments and I can't solve the problem, and the strangest thing is that today I upgraded to 11.2 and at least the screen color had been solved! But when I logged in the problem returned. I'm sending a pic of my EFI folder in case anyone can help me, Thanks! (sorry for the big text)
Screenshot 2021-02-10 at 19.53.35.zip
check your config.plist here https://opencore.slowgeek.com/ (select your cpu and 0C version ) update kext
no idea
