Olarila HackBeast Z490 VISION G with Thunderbolt - Full DSDT patches - Clover or OpenCore - Guide and Discussion
Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
A very custom DSDT for best experience under macOS. Removed all unused devices, injected all Apple devices, essentials, cosmetics, real improvements.
- Useful Links -
https://tinyurl.com/43t5m6d4
-OpenCore Vanilla TUTORIAL-
-USB Port Mapping TUTORIAL-
-Bios/UEFI Settings-
Serial Port = Disable
CFG Lock = Disable
If you have a Thunderbolt card
-Thunderbolt Configuration-
Security Level - No Security
GPIO3 Force Pwr - Enabled
-Hardware-
Mobo - Ga Z490 Vision G
Processor - i9 10th Intel
Cooler - CoolerMaster Masterliquid ML360R RGB
NVME - Corsair MP600
-EFI folders-
https://tinyurl.com/ybr968w3
Paste EFI folder into EFI partition, reboot and extract one SendMe. Post this dump here for full ACPI solution!
Download RunMe.app dumper
-DSDT Patches-
Quote
-FIX ACPI ERRORS
-REMOVE UNUSED SCOPES / DEVICES
-HIGH PRECISION EVENT TIMER
-SATA
-DMAC
-REMOVE PROBLEMATIC AND UNUSED DEVICES
-FIX K.P in REBOOT
-SLPB
-DARWIN / WINDOWS 2015
-XHCI
-PLUGIN TYPE
-HDEF
-REAL TIME CLOCK
-ARTC
-IRQs
-SBUS
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-FWHD
-USBX
-PMCR
-XSPI
-CNVW
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-DTGP
-HDMI / HDAU
-Screenshots-
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad and many, many, many others!
  • Like 3
  • Thanks 1
hello mald0n. Thank you for your great work.
I've used the attached EFI folder for OC and everything seems to be working fine except ethernet. It's recognized by the OS but I get "cable unplugged" in network's system preferences.
On the other hand my setup has a Titan Ridge 2.0 thunderbolt 3 Pci-e expansion card that is working fine with external hard drives. Unfortunately I've a Thunderbolt 2 Compliant Apple Cinema Display that I can't get to operate with this system.
Is there any workaround for this?
Best!
And thanks in advance.
PD; here's my dump:
https://www.dropbox.com/s/3jukce1cc7bxqfz/Send me TRIM5s-Mac-Pro.zip?dl=0
22 minutes ago, mLarry said:
here's my dump
Archive.zip
Ok, forget about it. I've reinstalled Catalina booting with this EFI folder and now is working like a charm!
Apple Cinema Display still off though.
Hello again Maldon. The hackbeast still working really well so I've decided to build another with the exact same components,. except CPU is 10700 non k instead of 10900K and GPU is RX 580 instead of 590 . I've applied the same files you provided me and it equally great but system profiler shows RX590. How can I change this? Do I have to resend you the dump for this setup specifically?
Best!
m
is just cosmetic
i apply this patch for some apps identify ur gpu
Thanks a lot ! I'm testing it and I have a question :
the RX 580 is seen as a RX570 (and I can't see the temp of GPU in iStats Menu); do u think this is fixable ? Or is this not a problem ? ;)
Thanks again
virtualsmc dont have plugins for gpu temp
 Hi Maldon, I tried to boot with your EFI folder but I got KP. I think it was about RTC, not sure. Had to switch to mine to be able to boot.
Send me NeRos-Mac-Pro.zip
Gigabyte Z490 - Vision G
Intel  Core i7-10700K
Saphire Radeon Pulse RX 580 4Gb
Corsair Vengeance RGB PRO 32GB (2x16GB) DDR4 3600 C18
Samsung SSD EVO 860 500GB
Corsair HX750 80Plus Platinum
41 minutes ago, Irish_Man said:
 Hi Maldon
Hi
this folder looks good
have a full solution
  • Thanks 1
