I successfully installed calatlina on my HP p211nk  laptop
CPU = i5 5200 U (Broadwell E)
HD5500 integrated gpu
However, I can't find the proper EFI folder.
this link doesn't have mobile 5th gen download. So, I can't boot off my ssd, only through the USB works.
Would you be kind enough to provide the required files?
Also, my laptop has Broadcom wifi. Any clues on how to make it work? I'm making this post through ethernet connection. Thank you for reading.
also, I followed clover guide. I can't find post install files like "disablehibernation" or "master-disable" in the installation media.
create one efi folder
check tutorial above
