DELL Inspiron 3593 i7 - 1065g7 laptop hackintosh ethernet port problem
Hello, good morning everyone, here is a newbie.
I share my problem with them in search of help to solve it, well it turns out that I have an efi that allows me to install big sur, the problem when I am in the installer tells me that I do not have internet, even though I am connected by the ethernet cable I try connect a usb wifi, but without success, I do not know what the internet error consists of, if someone has an idea how to solve it, I would really appreciate it.
Next I leave more corresponding information of the laptop along with the efi file that I use.
Processor:
https://ark.intel.com/content/www/es/es/ark/products/196597/intel-core-i7-1065g7-processor-8m-cache-up-to-3-90-ghz.html
Laptop:
https://www.dell.com/mx/p/inspiron-15-3593-laptop/pd
EFI file:
https://drive.google.com/file/d/1HhYdwnOJuxCpDFLHES_JA_TbMZAc1BUj/view?usp=sharing
I deeply appreciate your interest in helping me since I have just started with this wonderful world of hackintosh.
Edited by vicentyicopc
On 1/29/2021 at 9:19 PM, MaLd0n said:
Hi. Thanks for this.
I have the same exact laptop with Catalina installed via OpenCore. After doing a lot of trouble shooting, (almost) everything works except:
1) HDMI
2) Trackpad
3) Sleep
My question are as follows: the EFI posted above, what version of OC it was made with? Can you list here what works and what doesn't.
Thanks in advance.
is a basic efi. need start a fine tune after install
4 hours ago, Ahmet Mazlum Aras said:
Hello, I have the same device. Can you share the EFI again? No matter what I did, I could not gain HDMI support.
https://www.olarila.com/topic/25111-hackintosh-efi-folders-with-opencore-mod/
1) HDMI
2) Trackpad
3) Sleep
Thanks in advance.
Hi, how did you run HDMI? Can you share your EFI?
19 hours ago, MaLd0n said:
Thank you.
Edited by Ahmet Mazlum Aras
