Big Sur on X79-ZD3 Huananzhi, issues with FireWire Audio
UAR is already disabled?
Entry from DSDT
                    Method (_STA, 0, NotSerialized)  // _STA: Status
                        Return (^^SIO1.DSTA (Zero))
I researched and UAR1 seems to be the Serial Port, it is already disabled in the BIOS, also, when I tried to disable it with a couple of methods, I got hard crashes, KP report below:
panic(cpu 0 caller 0xffffff800d7abf7d): CPU 15 has no HPET assigned to it
Backtrace (CPU 0), Frame : Return Address
0xffffffa0b8c03c60 : 0xffffff800c28cfdd mach_kernel : _handle_debugger_trap + 0x3fd
0xffffffa0b8c03cb0 : 0xffffff800c3d3fd3 mach_kernel : _kdp_i386_trap + 0x143
0xffffffa0b8c03cf0 : 0xffffff800c3c45ca mach_kernel : _kernel_trap + 0x55a
0xffffffa0b8c03d40 : 0xffffff800c231a2f mach_kernel : _return_from_trap + 0xff
0xffffffa0b8c03d60 : 0xffffff800c28c7fd mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffa0b8c03e80 : 0xffffff800c28caf3 mach_kernel : _panic_trap_to_debugger + 0x273
0xffffffa0b8c03ef0 : 0xffffff800ca9cdca mach_kernel : _panic + 0x54
0xffffffa0b8c03f60 : 0xffffff800d7abf7d com.apple.driver.AppleIntelCPUPowerManagement : _pmInitThread + 0x2c7
0xffffffa0b8c03fa0 : 0xffffff800c23113e mach_kernel : _call_continuation + 0x2e
      Kernel Extensions in backtrace:
         com.apple.driver.AppleIntelCPUPowerManagement(222.0)[8B50AF31-4BF1-3BF1-81BD-BA02CFE3DDAB]@0xffffff800d7a6000->0xffffff800d7c2fff
Process name corresponding to current thread: kernel_task
Boot args: -v keepsyms=1 debug=0x100 darkwake=0 npci=0x2000 chunklist-security-epoch=0 -chunklist-no-rev2-dev chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
20G165
Kernel version:
Darwin Kernel Version 20.6.0: Mon Aug 30 06:12:21 PDT 2021; root:xnu-7195.141.6~3/RELEASE_X86_64
Kernel UUID: C2591F4E-EE82-33CC-8C59-DB81D9AD80DD
KernelCache slide: 0x000000000c000000
KernelCache base:  0xffffff800c200000
Kernel slide:      0x000000000c010000
Kernel text base:  0xffffff800c210000
__HIB  text base: 0xffffff800c100000
System model name: MacPro6,1 (Mac-F60DEB81FF30ACF6)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 92425050121
Last Sleep:           absolute           base_tsc          base_nano
  Uptime  : 0x0000001584f664c8
  Sleep   : 0x0000000000000000 0x0000000000000000 0x0000000000000000
  Wake    : 0x0000000000000000 0x00000033136bd172 0x0000000000000000
Anyway,  I swapped the cards, so they take up other slots and now the FireWire cards takes IRQ 11. I removed it from HPET and it takes 0, 2, 12 and 15, HDAU takes 4 or 5, so there seems not to be any conflicting IRQs ATM, but FireWire fails to load anyway.
Slowly I'm beginning to think, that the PCi bridge in the FW card is the cause of the issues, in spite it working with older kexts on Mojave and Catalina. I did try 2 cards, one with VIA chipset and one with TI chipset, but both have the bridge. Will maybe look for a one without the PCI bridge and check.
