JakubW Posted September 27, 2021 Author Share Posted September 27, 2021 On 9/25/2021 at 7:53 PM, MaLd0n said: https://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.ziphttps://olarila.com/files/Utils/IORegistryExplorer.app.zip After updating to 11.6 it got better. the device loads the driver, but is stutter, after a reboot it doesn't"t load. Note on ACPI I now use SSDTX79ZD3.aml instead of the DSDT (as You also did in the EFI folders) Send me Jakubs-Mac-Pro.zip And here the IOReg https://drive.google.com/file/d/1CGJmob-vdVf8Q4yOeI6qbOAH76yU7E5K/view?usp=sharing Link to comment Share on other sites More sharing options...
JakubW Posted September 27, 2021 Author Share Posted September 27, 2021 (edited) And here the IOReg https://drive.google.com/file/d/1CGJmob-vdVf8Q4yOeI6qbOAH76yU7E5K/view?usp=sharing I have an impression there is an IRQ conflict between HDAU and FRWR IRQ.zip Edited September 27, 2021 by JakubW Link to comment Share on other sites More sharing options...
JakubW Posted October 1, 2021 Author Share Posted October 1, 2021 his SendMe is from the boot, were the Firewire auto interface got enabled, the boot log shows the same error, so there must be something else pointing to issues with launchingg the audio interface. Anyway the interface rather won't load. There were also issues with the SSDT, so I switched back to the DSDT https://drive.google.com/file/d/15a55IGV9fk93S_Mmn5MqKLNnHVD8jnWj/view?usp=sharing Send me Jakubs-Mac-Pro.zip Link to comment Share on other sites More sharing options...
JakubW Posted October 4, 2021 Author Share Posted October 4, 2021 More and more I suspect, that the interrupt specifies, starting with 03 cause the issue, it may be related to the HPET as well IRQ 2.zip Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 4, 2021 Administrators Share Posted October 4, 2021 need work with default irqs patch -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
JakubW Posted October 4, 2021 Author Share Posted October 4, 2021 Yep, on Mojave it picks 04 in the HDAU segment of the GPU. I also saw, you moved the HPET to SBRG in the DSDT, did the same with an SSDT, now the boot is stable again. When I leave the OEM HPET and add patches to it, the system hangs, total freeze Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 5, 2021 Administrators Share Posted October 5, 2021 ye hpet inside low pin count device. in this case name is different -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
JakubW Posted October 5, 2021 Author Share Posted October 5, 2021 I found multiple values in UAR1, that have Benn blocked, including 3 and 4. Anything we could do, e.g. disable it and inject it again via SSDT with no IRQNOFlags? urrent Legacy IRQs: - SIO1: [] - PS2K: [1, 1] - PS2M: [12, 12, 12] - UAR1: [4, 3, 4, 5, 6, 7, 10, 11, 12, 3, 4, 5, 6, 7, 10, 11, 12, 3, 4, 5, 6, 7, 10, 11, 12, 3, 4, 5, 6, 7, 10, 11, 12] - PIC: [2] - TMR: [0] - RTC0: [8] - COPR: [13] Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 6, 2021 Administrators Share Posted October 6, 2021 kill UAR1 device -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
JakubW Posted October 6, 2021 Author Share Posted October 6, 2021 19 minutes ago, MaLd0n said: kill UAR1 device STA method in SSDT for example? Link to comment Share on other sites More sharing options...
JakubW Posted October 6, 2021 Author Share Posted October 6, 2021 UAR is already disabled? Entry from DSDT Method (_STA, 0, NotSerialized) // _STA: Status { Return (^^SIO1.DSTA (Zero)) } Link to comment Share on other sites More sharing options...
JakubW Posted October 6, 2021 Author Share Posted October 6, 2021 I researched and UAR1 seems to be the Serial Port, it is already disabled in the BIOS, also, when I tried to disable it with a couple of methods, I got hard crashes, KP report below: panic(cpu 0 caller 0xffffff800d7abf7d): CPU 15 has no HPET assigned to it Backtrace (CPU 0), Frame : Return Address 0xffffffa0b8c03c60 : 0xffffff800c28cfdd mach_kernel : _handle_debugger_trap + 0x3fd 0xffffffa0b8c03cb0 : 0xffffff800c3d3fd3 mach_kernel : _kdp_i386_trap + 0x143 0xffffffa0b8c03cf0 : 0xffffff800c3c45ca mach_kernel : _kernel_trap + 0x55a 0xffffffa0b8c03d40 : 0xffffff800c231a2f mach_kernel : _return_from_trap + 0xff 0xffffffa0b8c03d60 : 0xffffff800c28c7fd mach_kernel : _DebuggerTrapWithState + 0xad 0xffffffa0b8c03e80 : 0xffffff800c28caf3 mach_kernel : _panic_trap_to_debugger + 0x273 0xffffffa0b8c03ef0 : 0xffffff800ca9cdca mach_kernel : _panic + 0x54 0xffffffa0b8c03f60 : 0xffffff800d7abf7d com.apple.driver.AppleIntelCPUPowerManagement : _pmInitThread + 0x2c7 0xffffffa0b8c03fa0 : 0xffffff800c23113e mach_kernel : _call_continuation + 0x2e Kernel Extensions in backtrace: com.apple.driver.AppleIntelCPUPowerManagement(222.0)[8B50AF31-4BF1-3BF1-81BD-BA02CFE3DDAB]@0xffffff800d7a6000->0xffffff800d7c2fff Process name corresponding to current thread: kernel_task Boot args: -v keepsyms=1 debug=0x100 darkwake=0 npci=0x2000 chunklist-security-epoch=0 -chunklist-no-rev2-dev chunklist-security-epoch=0 -chunklist-no-rev2-dev Mac OS version: 20G165 Kernel version: Darwin Kernel Version 20.6.0: Mon Aug 30 06:12:21 PDT 2021; root:xnu-7195.141.6~3/RELEASE_X86_64 Kernel UUID: C2591F4E-EE82-33CC-8C59-DB81D9AD80DD KernelCache slide: 0x000000000c000000 KernelCache base: 0xffffff800c200000 Kernel slide: 0x000000000c010000 Kernel text base: 0xffffff800c210000 __HIB text base: 0xffffff800c100000 System model name: MacPro6,1 (Mac-F60DEB81FF30ACF6) System shutdown begun: NO Panic diags file available: YES (0x0) Hibernation exit count: 0 System uptime in nanoseconds: 92425050121 Last Sleep: absolute base_tsc base_nano Uptime : 0x0000001584f664c8 Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000 Wake : 0x0000000000000000 0x00000033136bd172 0x0000000000000000 Anyway, I swapped the cards, so they take up other slots and now the FireWire cards takes IRQ 11. I removed it from HPET and it takes 0, 2, 12 and 15, HDAU takes 4 or 5, so there seems not to be any conflicting IRQs ATM, but FireWire fails to load anyway. Link to comment Share on other sites More sharing options...
JakubW Posted October 15, 2021 Author Share Posted October 15, 2021 Slowly I'm beginning to think, that the PCi bridge in the FW card is the cause of the issues, in spite it working with older kexts on Mojave and Catalina. I did try 2 cards, one with VIA chipset and one with TI chipset, but both have the bridge. Will maybe look for a one without the PCI bridge and check. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 15, 2021 Administrators Share Posted October 15, 2021 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
