Hi, I have a hackbook MSI Modern 15 A10M Intel i5 10210U. I am using OpenCore 0.6.5
Everything is working great, except the built in web cam. It was working in Catalina but, after the update to Big Sur, it has stopped working. I have tried to enable it by using USBInjectAll kext but no luck. Is there anything else I can try to enable it? Thank you.
Edited by 91Snake
Solved, it was not an usb map issue, just an MSI config.
Now I do have a fully working hack ?
Edited by 91Snake
