OpenCore 0.6.5, Oralila vanilla, Haswell, Big Sur, MacPro 7,1
Hi all.
I am successfully running OpenCore 0.6.5, oralila vanilla install, Big Sur using Mac Pro 7,1 as my SMBIOS. The reason for the Mac Pro 7,1 is because I am using Radeon RX580. The RX 580 has hardware acceleration activated as confirmed by VideoProc.
However, Haswell is not "supported" by Mac Pro so it is reported as unknown CPU. The system works well though and this cannot be changed using CPU-Name (GitHub). The ProcessorType is report as "3842" and I cannot get any info on this number.
Anyway, my system is working well on SSDT-OLA with X86PlatformPlugin linked to CPU0@0 as viewed by IORegistryExplorer so I presume Power Management is working.
However, I tried to tinker by using RunMe.app and using the DSDT generated from there but X86PlatformPlugin is no longer seen if using DSDT.
So a few questions:
1. Does having an unknown CPU in system info affect anything or is it cosmetic only?
2. Does RunMe generate this DSDT without the X86PlatformPlugin only because the system has  "unknown" CPU?
3. Can someone point me where to get the ProcessorType integer? I can't find on Intel Ark.
I cannot attach RunMe SendMe file because it is bigger than allowed size.
1- cosmetic
2- runme extract ur original dsdt and tables from ur bios/uefi
3- use 3842
