Bigsur installation stuck at console relocated 0x402000000
use this folder with -igfxvesa and disable video patch for now
OMG... after use this folder with -igfxvesa...  now stuck at macbookpro 2020.local....
post one photo
apply windows patch and use voodooi2c kexts
Hi, thanks. the tackpad an KB work!. but a have another problems.
1. no fan detected in any app and the hackintosh run hot, fans are working every time.
2. BT not working, intel AX201, wifi works but BTfirmware ket not detect BT.
3. still no have energy saver preference pane .
4. macOS Big Sur don't come back from sleep.
thanks a lot.
here my file.
https://drive.google.com/file/d/1jP3NHqx-69qrJUBIrYPSwykLul_QkIra/view?usp=sharing
