Hi, i succesfully installed el capitan on an old pc : motherboard GAG31m es2l + intel core2Duo E84. System boots ok i have sound, Lan, graphics ok
but need help  with power management i guess ? because cpu is showing 75° celsius  and cpufan so noisy at 2200 rpm !
So i tried ssdt generator to get a ssdt file but it doesn't work it says : unknown cpu etc.. but About that Mac in the Finder  shows "3,0Ghz intel core 2 duo"
Anyway i think it is a problem with cpu management in my system, could you help please ?
Thanks in advance
(I've found a dsdt.aml file for G31 MotherBoard somewhere on website but maybe its not exactly same motherboard so maybe this is messing too)
joining the sendme result :
Send me tests-iMac.zip
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
use generate p and c states in config.plist
ok thank you doing this right now
Seems all right now ! cpu temp has drop down to 44° celsius and fan 900 rpm  !!
just ran ssdt generator but still gives me same error : " Unknown cpu"  but do i need a ssdt file anymore, maybe not ?
thanks again
ur processor dont need generate ssdt for PM
just use Generate P and C states in ur config.plist
Enjoy!
