Bootable Device Not Detected: Intel Nuc, Big Sur
Hi all,
I'm trying to install Big Sur onto my Intel Nuc, but I keep getting the error "A bootable drive has not been detected".  The USB doesn't show up in the bootable drives option, and I can only load it when I go into the NUC's bios settings and load from there.  I have no idea what Im doing wrong; could someone please help? I've been using the olarila guide.  I had previously managed to get it installed using Open Core but accidently overrode the ssd, now I'm stuck!
Edited by LittlePaws
what processor? ahci?
11 hours ago, thorasgard1 said:
Try this: https://github.com/shuai620/NUC7i7BNHv
Working well i have NUC 7i5bnh, processor is the same as your.
Hi, thanks for getting back to me, I'm getting the error
OCB system has no boot entries
OC: Failed to show boot menu!
Halting on Critical Error" Message?
Managed to fix the error through the guide; now at installation, fingers crossed!  Thank-you so much!
You must set disable security settings in config. Try this. Replace your config by this.
config.plist.zip
