Post Installation Questions for Olarila Catalina 10.15.7
Hello,
I have just installed Olarila Catalina 10.15.7 and I am now in the post installation phase.
I have the following questions:
1- The guides says that I should run 'disablehibernate.command' and 'master.disable.command' which should be in the Olarila Image/Files folder. The folder is there along with other utilities, but disablehibernate and master.disable are not there. Have they been moved? Or do I even need to run them in 10.15.7?
2- I am not sure which EFI folder to copy from the 'EFI Clover Serie 300, 400' from the site. There are 2 of them: one directly below the 'EFI Clover Serie 300 400' folder and one under _MAcOSX. Please advise.
3- My screen is pink and the screens are often not refreshing.  Any suggestions?
My setup is:
Intel I5 8400
Internal GPU via HDMI
16 Gig
Gigabyte Z370M 3CH MOBO
Thanks in advance for responding.
