Hi,
I'm running High Sierra on a Jingsha x99 d8 motherboard, e5-2678 v3, GTX 1060, everything is fine except USB 3
I tried just about everything I found, but nothing appears in IORegistryExplorer when I insert a USB flash drive.
I'm in High Sierra, I applied the limit patch, and put USBInjectAll.kext. Thanks
x99 D8.zip
use plugin type
Thank you MaLdon
I took your advice (I made a small donation by the way) and tried Opencore for the second time. I had tried it before and couldn't get it to boot, and that's why I went with Clover. Just like the first time I got the same result:
Stuck at IOConsoleUsers: gIOScreenLockState 3
use nv_disable=1
Nightmare, got back to Clover for the moment because I can't even boot with Opencore.
I finally managed to do usb mapping with USB.MAP by booting with USBInjectAll.kext and XHCI-unsupported.kext but by rebooting with USBMap.kext the Usb3 ports don't work, a usb flash ejects itself, it's very strange, sometimes the usb flash drive appears, sometimes not...
What to do ?
ur config is not good
Thank you men,
I've booted with the config file you send me first and the DSDT.aml. I have just XHC now for usb but it's still not working!
Here is the new dump
https://kmu.files.cnow.at/s/4iYyqJEb2issnZm
Did it, but unfortunately no joy.
Tried mapping with Hackintool and Usb.map but no, USB 3 not working
"Disk not ejected properly" for a usb flash after some seconds
ye
x99 dont us usb2 device, all work inside xhci device
