Need help with AD1988B on Asus P5E Deluxe
Hi, i cant get sound working on my P5E Deluxe, ADi1988B chip
I've tried many patches to DSDT, lot of kexts and it still doesn't work.. I'm using Hackintosh 10.7.4
Here is my codec dump.
http://justpaste.it/14sp
Can someone help me?
MoBo: ASUS P5E Deluxe | CPU: Intel C2D E8400 ~3GHz (SSE1-4.1) | Mem: 4x2GB DDR2 800MHz | GPU: ATI HD4850 | Aud: AD1988B | Net: RLT8139x | SB: Intel 82801IR (ICH9R)
Can't seem to get that driver to work in OSX Mavericks and yet I do have some injection in the DSDT for HDEF. It was working up to 10.8x.
Asus Maximus Forumula X38 chipset.
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 11.2.1, OpenCore 0.6.7.   New Asus Pro WS X299 Sage II intel i9-10980XE 18 core beast Big Sur 11.2.1. OpenCore 0.6.7,  Asus Z390-E i9-9900K 64GB G.Skill Ripjaws Sapphire Pulse RX580, Asus Sabertooth X79 (4) E5-2697 v2 (12 Core), Asus Maximus VIII Hero Alpha i7-7700K 64GB Corsair 2400, Asus Z97-Deluxe i7-4790K, Gigabyte Z77X-UP5-TH i7-3770k, Asus Maximux Formula Special Editions with Rampage Formula Bios conversion, Gigabyte GA-EP35-DS4, GA-EP45-UD3P, GA-G41M-ES2L, GA-Z68X-UD4-B3 and Quo MB.  MAC PRO EARLY 2008, MacPro Late 2012. Asus Notebooks: G51JX i7-720QM, G74SX-XT1 i7-2630QM, Asus G750JX-DB71 Haswell Processor i7-4700HQ GTX 770M 3GB (4).  Dell Laptops D820, D830, XPS M1530 (6), Dell 13-1567 (4), Older processors  i7 (3770K/4770k/6700k/7700K).  Older GFX Cards:  EVGA GT-640, EVGA GTX 760, EVGA GTX 770 (six),
This one works for me on Mavericks (layout-id=4 in DSDT)
http://Olarila.com/files/10.8/Audio/AppleHDA/ADI1988B/AppleHDA_for_ADI1988B.zip
This is what I had before editing DSDT:
            Device (HDEF)
               Name (_ADR, 0x001B0000)
                   Store (Package (0x08)
                           "codec-id",
                           Buffer (0x04)
                               0x9B, 0x82, 0x43, 0x10
                           "layout-id",
                           Buffer (0x04)
                               0x03, 0x00, 0x00, 0x00
                           "device-type",
                           Buffer (0x17)
                               "Analog Devices AD1988B"
                           "PinConfigurations",
                           Buffer (Zero) {}
                       }, Local0)
                   Return (Local0)
Edited with your code:
            Device (HDEF)
                   Store (Package (0x0c)
                       "built-in",
                       Buffer (One)
                           0x00
                       "layout-id",
                       Buffer (0x04)
                           0x04, 0x00, 0x00, 0x00
                      Buffer (0x00)
                          0x00
                   }, Local0)
                   Return (Local0)
       Scope (\_GPE)
Message when compiled:
/Users/osxfr33k/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl  6533:             Method (_DSM, 4, NotSerialized)
                       "built-in",
                       Buffer (One)
                           0x00
                       "layout-id",
                       Buffer (0x04)
                      Buffer (0x00)
                          0x00
                   }, Local0)
                   Return (Local0)
Remark   5048 -        Initializer list shorter than declared package length ^
Just replace 3 by 4 in layout-id, don't need to edit other keys.
And why did you set package length to 0x0c (12) if you actually decreased it from 8 to 6?
I just realized i should have changed that from 8 to 6. I forgot the reason why , but I have to assume that between each {} is a count of 1?
Thanks very much for your help!!
Values are separated by comma.
5 commas, 6 values.
5 commas, 6 values.
Thanks Again Audio working 100%!!
Hi Oldnapalm,
Would you happen to have the latest version for Yosemite 10.10.2?
EDITED next day:
Found a working one from your Thread over at Insanely. The one you posted with SPDIF "in" gives me all the ports for both output and input. Thanks
Hi, I'm using this "dummy" kext, it works from 10.10 to 10.10.2
AppleHDAADI1988B.kext.zip
If you want patched kext you can use this app
http://Olarila.com/forum/viewtopic.php?f=9&t=4487
