[Help] OC with Big Sur on a new Ryzen machine
Hey guys, I had in past a Sandy Bridge i5 using Clover and High Sierra, so experienced a bit of hackintosh world (not much).
Now I bought a new machine and still struggling with Ryzentosh.
Hardware:
- Asus TUF X570-Gaming Plus
- Ryzen 5 5600x
- Gigabyte 5700 XT
- XPG Gaming 2x8gb DDR 4 3200mhz
- XPG Adata NVME 240gb
So here's the deal, I tried to create a Big Sur image on my windows, using OpenCore, downloading that online image and also building my EFI.
My usb drive have two main folders: com.apple.recovery.boot and EFI
Currently I'm stuck at two errors:
OCUI: failed to load images
OC: External interface failure. fallback builtin - Unsupported
I tried to use some tips here and some apps, but they're though since I don't have an easy mac to play around.
Attaching my EFI folder here with config.plist also inside.
Any tips? Thank you in advance.
EFI.zip
disable csm
Hi, thanks again for the quick response.
So, my Mobo was with CSM as disabled.
One thing that I tried after that is to enable it and force UEFI mode only, and after that I could see much more command lines appearing until it suddenly goes to a black screen and stay that way for several minutes (at least).
I know it's the opposite you suggested but I was experimenting just because Disabled won't work.
Is there anything else on BIOS settings that could prevent my Big Sur installation maybe?
Thank you again.
Hey, just passing by that I could make it work now, it was missing the boot argument agdpmod=pikera
Just installed successfully, now will study a little bit to fix some minor issues like sound problem and other stuff... thank you in advance!
