[HELP] OC "StartImage failed - Aborted" on 10.15.7
Hello,
I have installed macOS Catalina 10.15.7 with OpenCore 0.6.4 on a i9-9900K, UHD 630 and Gigabyte Z390 I Aorus Pro WiFi motherboard by following the guide below: https://dortania.github.io/OpenCore-Install-Guide/config.plist/coffee-lake.html
The problem I'm having is that once I select the macOS partition in OpenCore, sometimes (not always) I get the error that you can see in the photo. When this error appears, it usually repeats the following times until I clean the NVRAM.
I also attach the config.plist.
Any ideas?
Thank you.
configplist.zip
