I was able to install Mojave and Catalina with no problem here, did not install any EFI to the NVME since I was trying to check if it was some mistake at my BIOS settings
I was not using Hackintosh for a while since I was using Nvidia 1060 and now I got a 5600XT
I know my CPU is from older gen (1155 i7-3770K) but it has a good and stable overlock fixed at 4.7 and using a PCIE nvme (Corsair 510 2tb) that works fine with Mojave and Catalina (10 min install)
Motherboard ASUS Sabertooth Z77 with 4 x 8GB Gskill TridentX 2666Mhz
It has a few addon cards (4 ports realktek LAN (using only the 1st port now, and Mojave and Olarila works fine) Firewire, ASMEDIA sata controller) and a USB 3.0 PCIE too
it says something about wake failure and some kernel stuff I really don't understand
Got the image from mediafire (the updated one)
Tks
20201208_100931men.zip
On 12/10/2020 at 12:33 AM, MaLd0n said:
Hi
Clover still stucks in the ++++++ signs and Opencore was having ACPI states hanging in the installer (acpi sleep states s3 s4 s5)
I used nullpowermanagement kext inside opencore kext folder and now it booted to the installer and when it was 13 min to finish it had a kernel panic regarding iographics
Gonna try not using my ACPI settings and if still fails gonna install Catalina only to be able do dump and reassemble ACPI tables
Tks
9 hours ago, crisorlandobrsp said:
Hi
Tks
Remove this kext. Use Kernel->Emulate->DummyPowerManagement.
Use agdpmod=pikera boot-flag for your graphics. NVRAM -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 ->boot-args
AMD Ryzen 9 3900X
ASUS ROG STRIX X570-E GAMING
Sapphire Nitro+ Radeon RX 590 8GB
CORSAIR Vengeance LPX 32GB DDR4 3600Mhz
Hi
I was able to install with no problems before seeing the reply
Everything works fines but overclock and the new GPU (Navi) does not show temps
Tks
