Hey Guys, I have Big Sur installed full version and runs perfectly until I changed my cpu from i3 7100K to an i7 7400. I am using OC to boot. Under overview for Mac it shows Processor as 3 GHz Quad Core Intel Core i3 and Graphics shows Intel HD Graphics 630 31MB. I cannot run web pages as the computer takes for ever to load and freezes but if I put my actual i3 CPU back it all works perfect again. running OC 0.6.3 the prebuilt version of @MaLd0n. PLZ HELP
Gigabyte Z490 Vision D
i7-11700K RocketLake
Powercolour RX6800XT
MacOS Big Sur
Monterey
The CPU I installed is this: Intel Core I7-7700 ES QKYN - got it cheap of AliExpress and I really want to make it work
IMG_0096.img.jpg.zip
MacOS Big Sur
Monterey
use 59128086 and 59120000,  add igfxonln=1
Thanks, will try that
@MaLd0n Okay, stupid question for me, Where do I add those in, I check open core config and don't know where to put it in
MacOS Big Sur
Monterey
use device properties
@MaLd0n Please help, I tied and failed, it does not boot up with whatever edits I tried adding to device properties it just gets stuck on the apple bar half way
And for some reason my sound does not work anymore and the only resolution I can select under display now is 2660x1440 and it shows my monitor as 41 inch, with the other cpu I could select 1080p, had full sound via HDMI
MacOS Big Sur
Monterey
bro
u need check with hackintool a best propertie for ur igpu
