macOS Big Sur Opencore 0.6.3 Battery Drain
Hey Guys, I created my Big Sur Installation and I'm happy to report that (almost) everything is working. I do have one problem i.e. the battery life. My battery last for only like 70-80 minutes. In Windows I can get more than 3.5-4 hours on same usage. I used CPUFriendFriend and added the kext but its still not great.
My Specs:
HP Pavilion 15 Gaming Laptop
Intel i7-9750H + UHD 630
Nvidia GTX 1650
16GB RAM
128GB SSD + 1TB HDD
Here is my EFI. Can someone please give some pointers?
Thank You
Note: I removed kexts and resources folder to comply with file size limits. You can find my kexts through config.plist
EFI.zip
On my HP, Result is quit similar if possible turn OFF dGPU completely if possible do it from Bios. From SSDT some how it consumes power.
Brightness levels are same with both OS ? If brightness levels are comparable then need to fix you Intel Brightness
Edited by Dec_Bra1n
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
@Dec_Bra1n Thank You but I would like to point out that on this same laptop I have had a very solid battery life (better than Windows) in macOS in the past. This time around I just tried creating things from scratch and I believe I have missed something. With regards to dGPU I disabled it using -wegnoegpu. Do I still need to disable it using SSDT (I can't disable using BIOS).
Try using  SSDT way here are the example of making  SSDT-dGPU-Off
using -wegnoegpu will disable dGPU but not powe consumtion will be there
Edited by Dec_Bra1n
