I have full acceleration with my GTX770 which is hooked up to two monitors, perfect!
I've also got two additional monitors which are hooked up to my onboard video, HD 4600, but
on that onboard video just one of the monitors will work, I attached some screenshots.
Is there any tweak to get the second monitor connected to the HD 4600 to work as well?
Edited by theplague
Intel Core i7 4790
Nvidia GTX 770 4GB
Asus H97 PLUS
the best is used only only gpu with monitors
u can stay with intelhd enable but all monitors stay in dgpu
I see, I used a converter to connect the VGA monitor to the Intel HDMI port and it worked, but the resolution between the two monitors connected to the Intel HD 4600 was shared, every time I changed it on one monitor the other one would also switch.
I'll look into connecting all displays to the GTX, thank you!
Intel Core i7 4790
Nvidia GTX 770 4GB
Asus H97 PLUS
