Realtek RTL8111 not working, says cable disconnected
Not sure what else to do since the kext seems to be loaded into memory, what am I missing here to get it to work?
I would appreciate any tips!
Intel Core i7 4790
Nvidia GTX 770 4GB
Asus H97 PLUS
2 hours ago, theplague said:
Nejste si jisti, co jiného dělat, protože se zdá, že se kext načítá do paměti, co mi tady chybí, aby fungoval?
Ocenil bych jakékoli tipy!
Hi .. I have the same problem. My board GA-B150M-DS3H with Intel Core i5-5600, Radeon RX 560 4GB .. I've been looking for 3 days .. :-(
And I also have a problem with booting the system. Even if Clover is installed, Catalina will not start. I also tried to overwrite the data from Install Flash to EFI, but to no avail .. Please help me ... I'm already desperate and I have no idea what I'm doing wrong .. Thanks a lot ..
IMG_20201201_180152.jpg.zip
what?
use in bootloader folder only
24 minutes ago, MaLd0n said:
co?
použít pouze ve složce bootloaderu
OK .. So far boot from flash and I installed it in EFI folder .. I copied it to flash and it works .. Can you please still advise me how to create a functional boot from SSD? Thanks so much for this help ..
