Bart Rap Posted December 19, 2020 Author Posted December 19, 2020 (edited) csm is definately disabled ok i will try your EFI folder again;I have disabled the thunderbolt in the bios and also internal graphics= disabled; then i could boot again without getting the 'could not allocate....' crash. Here are the results Daniel; I removed the firewire card to see if that would help. Just also to confirm my setup; a designare z390 board rev 1.0 with BIOS F9i. My processor is an intel i7 (not i9) 9700K; Graphics board is an MSI RX 580 Gaming X. I have made a preboot log file, some screenshote, a IOReg file and new send-me files based on the boot with your EFI folder. Thanks again ? Bart’s iMac IOReg.zip Send me Barts-iMac.zip latest screenshots.zip preboot.log.zip Edited December 20, 2020 by Bart Rap
Administrators MaLd0n Posted December 20, 2020 Administrators Posted December 20, 2020 the problem is: this efi folder is not good. we need update it. extract tables with f4 key in clover boot screen, files generated in clover/acpi/origin, send me these files -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 20, 2020 Author Posted December 20, 2020 Hi Good morning; Ok I have done as you said; I started up with your EFI; at the clover boot screen I pressed F4; I send you the files from clover/acpi/origin now and a latest 'send-me' file and IOReg... Bart’s iMac IOReg.zip origin.zip Send me Barts-iMac.zip
Administrators MaLd0n Posted December 20, 2020 Administrators Posted December 20, 2020 Archive.zip u can use ur folder, just use acpi and kexts files reboot and save one ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 20, 2020 Author Posted December 20, 2020 (edited) Hi Daniel; Thanks. So I will use the current EFI folder and will replace the acpi and kext files in it with the ones you have sent me now; will be right back with the results Making progression Daniel! System boots; I guess there is some pollution in the EFI files because mixed EFI's are now used -- But the system boots fine now. Still, I have not enabled the Thunderbolt interface yet in the bios; will try that in a bit. The thunderbolt was actually enabled in the bios; Good; although it doesnt show in the Mojave system overview; but that is normal I think you said right ? Here is a IOReg copy that you requested; just to be sure I will also add a fresh 'send-me' file. Send me Barts-iMac.zip Bart’s iMac IOReg.zip Edited December 20, 2020 by Bart Rap
Bart Rap Posted December 21, 2020 Author Posted December 21, 2020 Hi Daniel; Tomorrow I will get the UAD Arrow Thunderbolt 3 device so I can hook it up. One thing that occurs to me in the current setting, is that the front side usb, only the usb 2.0 senses usb sticks. the 3.0/3.1 is not detected. I have installed a Big Sur Olarila version on a seperate ssd (Works perfect!). On that ssd all usb ports are recognized; you think you can fix it on the Mojave one ? Thanks !
Administrators MaLd0n Posted December 21, 2020 Administrators Posted December 21, 2020 send me ur full efi folder -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 21, 2020 Author Posted December 21, 2020 (edited) I tried to send you my EFI folder but it is 22 MB in size; I get a messsage I am limited to 19.53 MB.... PS I notice that the onboard audio device is also not available.... Edited December 21, 2020 by Bart Rap
Administrators MaLd0n Posted December 21, 2020 Administrators Posted December 21, 2020 up in google drive or other service -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 22, 2020 Author Posted December 22, 2020 (edited) Ok; does this work for you ? https://bartdisk.myftp.org:5001/sharing/bqcFp5s5d Edited December 22, 2020 by Bart Rap
Administrators MaLd0n Posted December 22, 2020 Administrators Posted December 22, 2020 back up and delete ur efi folder and paste this efi folder, reboot EFI.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 22, 2020 Author Posted December 22, 2020 Hi Daniel; Will do it soon; got my UAD Arrow audio interface and wanted to let you know it already works !Woaw !!! Ok tomorrow I have to work abroad for 6 days; so I try to replace the EFI folder tonight, or otherwise after the work period. Will keep you updated ! Bart
Administrators MaLd0n Posted December 22, 2020 Administrators Posted December 22, 2020 k -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 22, 2020 Author Posted December 22, 2020 Just replaced the EFI with yours; unfortunately same result; onboard (motherboard) audio not available and also USB 3 front side not reactive; USB 2 frontside still works. I made some fresh troubleshoot files.... Obrigado! Bart’s iMac IOReg.zip preboot.log.zip Send me Barts-iMac.zip
Administrators MaLd0n Posted December 22, 2020 Administrators Posted December 22, 2020 put two kexts un clover/kexts/others and replace Archive.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 22, 2020 Author Posted December 22, 2020 Hi Daniel; just did what you said but it had no effect on both the audio and the usb 3 ports... Am now off to work for 6 days or so; see you later and thanks for the effort; I enclosed the latest updated files... preboot.log.zip Send me Barts-iMac.zip Bart’s iMac IOReg.zip
Administrators MaLd0n Posted December 23, 2020 Administrators Posted December 23, 2020 ok let me know if u have time. we solve it via telegram or whatsapp -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted December 23, 2020 Administrators Posted December 23, 2020 6 hours ago, Bart Rap said: Ok great! Merry Christmas!??♂️?? Thx bro same to u and urs! -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bart Rap Posted December 28, 2020 Author Posted December 28, 2020 On 12/23/2020 at 4:37 AM, MaLd0n said: ok let me know if u have time. we solve it via telegram or whatsapp Hi Dan; Hope you had a great Christmas; Am just back from work. What would be a good time for you to go on whatsapp ? I will send pm you my phone number. I am in the CET time zone here in Holland (UTC+1).
Bart Rap Posted December 28, 2020 Author Posted December 28, 2020 I just checked with booting on your Olarila BigSur SSD; then all usb ports and audio work fine....
Administrators MaLd0n Posted December 30, 2020 Administrators Posted December 30, 2020 check whatsapp -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
