ASRock Z390 Extreme4 Mojave with added Thunderbolt3 AIC R2.0
Hi Daniel; In the meantime I have created a completely clean install of your Mojave Olarila Imageand that works fine; I still will try to work on the older Mojave ssd with all my programs on it later tonight and will do this what you said;
use clover
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
However; can you create a dsdt for my new clean install ? Here is the send me file for the new one; thunderbolt card doesn't show yet, but the system boots at least normal... Cheers, Bart
Send me Barts-iMac.zip
k
just replace clover folder inside efi folder
Hi Daniel; Am back from a heavy working week abroad :-)...
Okay; where did we leave it ? Should I replace your created EFI folder in the fresh install ssd or in my older Mojave ssd that has all my programs installed ? In both the old and the fresh install, the thunderbolt card is show 'no hardware was found' when I check it in system report.
Let me replace the EFI folders in both new and old Mojave ssd's to see what happens; will keep you posted....
Cheers, Bart
is common but work
check in bios/uefi if have...
-Thunderbolt Configuration-
Security Level - No Security
GPIO3 Force Pwr - Enabled
Hi Daniel; I have changed the Thunderbolt card into PCIe slot #6 and have selected the link speed to GEN3. I made some progression, because now the ssd with Mojave and apps installed boot normally. Now I have to wait until I receive my new UAD TB3 Audio interface, to see if everything works. Will keep you advised. Thanks again! Bart.
Also I have made some latest IOReg and 'Send-me' files, for your information. Have a nice weekend !
Send me Barts-iMac.zip Bart’s iMac old ssd with thunderbolt inserted IOReg.zip
thunderbolt is not load
what tbh card u have?
I have an ASRock Thunderbolt 3 AIC R2.0 card.
It would be great to get everything working on my ssd with Mojave and the apps installed, as it took me a long time to have all the installed apps and plugins to work.
The IOReg file and the send me file are freshly created from my Mojave audio apps ssd.
Maybe it is usefull for you to know that many times before I get a succesful boot (see screenshot attached), I end up with a hung system. Could it be that the thunderbolt card needs a certain boot time before it is ready ?
Have a nice sunday Daniel!
IOReg Bart’s iMac.zip Send me Barts-iMac.zip unsuccsefull boot.jpg.zip
bro. some tbh from asrock mobos dont work. have a problemactic things
Thanks Daniel; I have returned the thunderbolt card to my supplier. It's a pity because I would have really loved to have thunderbolt 3 on my asrock motherboard, but if it gives to many problems, then I rather spend that time in making music. Thank you for your time Daniel; Will start to look for a motherboard with thunderbolt 3 onboard....
Have a marry Christmas and a wonderful 2021; Cheers from a locked down Netherlands,
Bart
Thanks for that tip Daniel; I would like to use my processor (i7 9700K socket 1151) and other parts on the new motherboard; would a designare z370 with thunderbolt onboard be good as well ?
z390 designare for this processor
https://www.olarila.com/topic/6531-olarila-hackbeast-z390-designare-thunderbolt-full-dsdt-patches-clover-opencore/
