Big Sur Opencore booting from USB and not working from SSD EFI
Hi
I have a working version of Big Sur installed on a fresh SSD, AMD Fx system (990fxa-UD5, fx8350 processor, AMD580x graphics).
Booting from my OpenCore USB stick works perfectly. I copied the content of my USB to the SSD EFI partition. So I would expect this would work, like it always did in the past with all previous MacOS versions. Not this time. When I select the Big Sur in the boot picker, I get an immediate kernel panic.
I included the OpenCore log for the 'Working USB' and the 'Not working SSD' EFI. Again, it's an exact copy, so I do not get why this does not boot.
Has anyone seen this before?
Thanks!
Opencore logs.zip
same folder?
same folder from usb into ssd?
