Hello, I recently enrolled in this forum and tell you my problem, I've updated to big sur 15.0 and with several attempts I managed to do it but it doesn't work as well as I should, I let you leave my settings to see if you can help me and what I should do.
Base: MSI B365MPRO-VD.
CPU: Intel Core i5-9400F 2.9GHz. RAM: Kingston HyperX Fury Black 16GB DDR4 2666Mhz PC-21300 CL16
Video card: Sapphire Pulse Radeon RX 550 2GD5
SSD: Two Sandisk Ultra 3D SSD 500GB SATA3.
Well, this is the configuration attached to you Dsdt and if you can use CLOVER OR OPENCORE. Without more, thank you very much in front of hand.
DSDT.aml
