Mochamad Aditya Ramadhan Posted November 26, 2020 Posted November 26, 2020 (edited) My spec system : ASUS H81M-D Plus Core i5-4690 3,5 Ghz Haswell 8 Gb ram VGA RX 570 Phantom Gaming Installed disk : SSD Apacher AS340 120gb I have successfully installed Big Sur with clover on H81M-D Plus with a few trick that I know, but still I Thinks its not fully optimized, I have a few question : - I boot from the partition PREBOOT (not the partition where I installed hackintosh bus its cause kernel panic) its normal or its a problem, if its a problem how to fix it ? - I saw text “unsupported cpu” when I booting into system, how to fix it ? - I installed hackintosh to ssd, but its not fast as windows, I saw in system information it said the TRIM SUPPORT = no, does it affect the hackintosh system on ssd? because I heard from people that if Hackintosh is installed on SSD, “TRIM SUPPORT” should be “Yes” - My vga RX 570 sometimes lag when I open app (even open Facebook on safari makes lag), there’s any fix ? I Think that’s all my questions, Sorry I still learning about hackintosh, I still don’t understand about patching DSDT or anything related about post-installation hackintosh here’s the file : http://s000.tinyupload.com/?file_id=00031618378713439417 and I attached my pci list devices, maybe you need it, Thanks you pci-devices-bigsura.zip Edited November 26, 2020 by Mochamad Aditya Ramadhan
