I use an asus x 99-m + 2640v3, the problem is that when I prescribe the layout , I have A very long MacOS boot. Audio outputs are still missing, I tried installing VoodooHDA.kext - only HDMI is visible with it. I have tried various ways to fix this problem - but so far without success. Can someone help me?
Архив.zip
what ur gpu? some gpus apple applealc try inject hdmi audio and cause very slow boot
Now there is a GTX 770, as I understand it, it is because of it very slow loading? How can I disable its HDMI ? Probably because of her conflict.
first remove applealc and check
19 hours ago, MaLd0n said:
сначала удалите applealc и проверьте
If I delete the layout, the system loads quickly.
