Need help on fine tune Big Sur with Open Core in laptop Alienware 15r2
dont need use system folders
use bootloader folder to inject kexts
Dear Madlon,
I do not know why but the touch screen only work if I put kext in LE, may be have problem with preparation for pin GPIO to make I2C work --> That's not big thing, so no problem. Now my Hackintosh system run smoothly, can daily use --> Thank for your help!
When using, I still faced up with 02 small errors:
1. The time of system --> When laptop sleep, the clock in laptop not run (battery of laptop normal in Windows) --> When I open again laptop from sleep, the time show wrong, only synchronized when I connect laptop to the Internet Send me Tiens-MacBook-Pro.zip
Tien’s MacBook Pro.zip2. Sometimes when laptop go into sleep state --> I can not open again by power button, backlight of keyboard/HDD still bright, the screen still black --> Only have way to power off laptop by press power button and power on again
I put file Runme and IOREG in attached file. Could you please help me to review DSDT file to have way to fix 02 above errors.
Thanks so much!
send me ur config.plist
