Need help on fine tune Big Sur with Open Core in laptop Alienware 15r2
touchscreen need check voodooi2c. use VoodooI2C.kext and VoodooI2CHID.kext
if u use voodoops2 with VoodooInput.kext, remove this plugin inside VoodooI2C.kext to avoid conflict. both kexts have this plugin
back to previous dsdt
about charger i never see that. very strange problem
post one photo in error screen with charger on
It means when my laptop completely turn off, I can not power on my laptop if not plug in the charger, as this picture:
https://ibb.co/r78JQWW
With your above DSDT, I can do that but unluckily it’s boot stuck
For touch screen, I go inside to VoodooI2C kext —> Show Content —> Plug ins —> Delete voodooinput but still nothing change
Edited by Cao Dat
post here dsdt working
Thank Maldon,
I have tested DSDT file, system can boot, but the issue of can not turn on if not connect charger and no touchscreen still remain. I will spend weekend to test more. If you have any idea to modify DSDT to fix 02 above issue, please help me
On 12/4/2020 at 7:27 PM, MaLd0n said:
All after hairs fallen, I've fixed the problem of lid wake/sleep wake --> It's by AAPL,ig-platform-id, the previous one I choose wrong (do not know why the screen can go inside), now I use the value 00001E19 --> It's run smoothly.
For the problem when shut down laptop, if not connect charger can not turn on laptop by power button --> My battery health still 80%, I think research later because my laptop always go with charger. A little bit inconvenient by need charger the same as starter of car when laptop fully turn off, without starter no power on.
Now remain only how to enable my ELAN Touch screen. I do not know just paste the kext to OC folder or need to do other steps more like PIN configure, SSDT GPI0, XOSI...? Could you please guide for me the way to enable it?
Edited by Cao Dat
don't need xosi, u have it in native device
save one ioreg
add these kexts
Archive.zip
this trackpad load inside usb. idk if work
What does idk mean?
Edited by Cao Dat
i dont know :P
9 hours ago, MaLd0n said:
i dont know :P
? Please help me, I ask because I really do not know that word.
When I put the kext, touch pad ok, recognize.
but for touch screen, do you think that need to set up Pin configurator?
6 hours ago, Cao Dat said:
?but for touch screen, do you think that need to set up Pin configurator?
usb devices in many cases just need kexts inside bootloader folder ;)
In Catalina, I can go over by put VoodooI2C and VoodooI2C HID into Library/Extention. May be that way support to load kext into bootloader. But in Big Sur, may be Apple lock to put kext into LE
Edited by Cao Dat
