Currently I have Mojave working at 100% and with the fine tuning of Maldon DSDT "thank you master" everything works perfectly, I use Clover 5112, I have been trying to create my configuration with the latest version of openclore without success, I have spent a lot of time and I can't I start the installation, surely due to lack of knowledge I will be doing something wrong, I have seen that there is the option to keep Clover but I do not see many comments in the forum about this option, I would ask you for some help if someone has their EFI folder with a configuration that matches that of my computer to see if it works and thus find out what was wrong, I would not care if it is opencore or clover if the system works stable, thank you very much everyone for your help.
Asus Z370-F Gaming
I7 8700K
32 gb Memory Ripjaws 3000
Samsung 970 pro
