Big Sur less than a minute problem
big sur is a fight for some hardware ;)
HEY MaLd0n i need your help please check my efi and config i am not able to see usb mac os installer can only see apfs drive to install big
Edited by prabhat04
what u create ur usb stick? hfs and apfs is there. the problem is other
I have fixed my config that was some acpi patch for USB now big sur got installed but now I have to fix display touch pad and brightness
In previous Catalina efi I have full brightness control how to copy that
the patches is same
7 hours ago, MaLd0n said:
the patches is same
I got my brightness and gpu fixed now my audio and touchpad is problem what to do in windows I got device I'd as Etpd1 and audio alc 256 realtek
my icelake work like a beast
just need fix trackpad after sleep, but is a voodooi2c problem
Please check this I have same problem I have i3 you have solved this problem what is that the alc 256 and same asus ice lake like laptop
I have elan 1200 trackpad which kext to use voodoi2chid or elan kext
try with FakePCIID.kext / FakePCIID_Intel_HDMI_Audio.kext and alcid=13
Didn't work I have tried on Catalina many too I know I have the same problem like him in stated above post can you help what you solved
fixed apple alc audio now can you please help to fix resolution as on 14 inch laptop content is relatively small @MaLd0n
and what s the use ssdt hpet and irq conflicts  do i include that too in my efi  for now just sleep and whatever green  drm on safari not working and trackpad just lag on login screen
Edited by prabhat04
