Yhogakafi Posted November 12, 2020 Posted November 12, 2020 (edited) Hi, please hep me. Asrock h61m dgs r2.0 Intel i3 3240 Asus GTX 1050 2gb 2x8 gb ram 1tb Adata HDD Here's what i've been done : I've made high sierra usb installer trough vanilla clover install guide in this forum (using win32diskimager for burning the raw file) I've disable intel virtualization (VT-d not available), serial/IO port, security boot, and set to AHCI Boot into clover Install high sierra My mouse working in language selection Erase my 1tb HDD, format into Macos extended journaled (in guide written it should be APFS, but it for SSD, and i've read from someone for HDD it should be macos extended format, Am i wrong at this point?) Then install, took about 16 minutes, restart Boot clover, boot from HDD 1tb, at this point my screen shows a lot of thing i couldn't understand, then it stuck in crossed circle, so i force shut down my pc, and booting again from HDD 1tb Boot again, show apple logo, choose language (my mouse still working) and then, when it ask to enter username pc my USB keyboard isn't working, so i use my PS2 keyboard instead and it work. Boot into mac dekstop, and before i wanna get into next step to run "disablehibernate.command", i took off my keyboard and plugged in my PC's frozen, so i force shutting it down again After that, i boot it again, at this point my mouse isn't working. But my USB keyboard is working, (How do i know? when i push shut down button in my pc, my screen show shutdown promt, i click enter/return and it shutting down) So i'm not copying efi folder from folder chipset already yet. Also, is it correct if i choose this folder for my i3 3240? --NOTEBOOKS CHIPSET SERIES 5, 6, 7, 8, 9 (NEHALEM / SANDY BRIDGE / IVY BRIDGE / HASWELL / BROADWELL) https://tinyurl.com/vyuykfs I attach my usb EFI folder screenshot, i access it trough vmware in Windows, do i need to delete some kext based on my pc requirement? Thank you very much Screenshot_1.rar Edited November 12, 2020 by Yhogakafi Make it clear
Administrators MaLd0n Posted November 12, 2020 Administrators Posted November 12, 2020 Tried other usb port? 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Yhogakafi Posted November 12, 2020 Author Posted November 12, 2020 28 minutes ago, MaLd0n said: Tried other usb port? Hey, thanks, it works. But, I'm confused. It works when i plug it on front panel. The problem is, i only have 1 port in front panel, so i can't use it together with my USB drive. Are there any fix for this? So i can use port in back panel also?
Yhogakafi Posted November 12, 2020 Author Posted November 12, 2020 2 hours ago, MaLd0n said: Tried other usb port? 1 hour ago, Yhogakafi said: Hey, thanks, it works. But, I'm confused. It works when i plug it on front panel. The problem is, i only have 1 port in front panel, so i can't use it together with my USB drive. Are there any fix for this? So i can use port in back panel also? Ok, now i figured it out that only 2 port i can use, 1 front and 1 back. And i've copied the downloaded efi clover folder to my efi folder in my HDD, but still i can't boot from my harddisk.
Administrators MaLd0n Posted November 12, 2020 Administrators Posted November 12, 2020 Post one Full Dumphttps://www.olarila.com/topic/10301-olarila-runme-dumper/https://olarila.com/files/Utils/RunMe.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
