Mouse / frame lag on Catalina 10.15.7 OpenCore
Hi!
So i yesterday i requested a DSDT Patch and everything works fine. One thing that could not be patched with that, i doubt it can be patched with a dsdt, is my mouse/frame/gpu lag.
I dont really understand where it comes from. I tried different mouses (cable, bluetooth etc.) and it still happens.
From what i found out it must be my GPU. Every few seconds my image freezes for a microsecond. Weirdly i dont notice that while watching videos on youtube etc.
In safari i cant use netflix eventhough i tried shikigava=80 / 40 / 128 as boot arguments.
Also my wifi does not work. It registers all the networks and i can type in a password but then i get "cant connect to network"
My setup:
RX5500 (tomorrow i will have a GB RX5700 XT to test)
i9 9900
Gigabyte Z390 Pro
BCM943602CS (Bluetooth working, WiFi not connecting)
I will upload my EFI & video examples here. Maybe i did set up something wrong...
Video: https://easyupload.io/m/zu9fp6
EFI: https://easyupload.io/zzmhbc
Also i looked into hackintool and it seems that the card has the wrong device ID and the kext AirPortBrcm4360 is being used for the card.
Screenshots: https://easyupload.io/m/1d8ts8
Thanks very much!
Edited by beatboi1
use imacpro1,1 with igpu disable and shikigva=128
Hi MaLd0n! I already tried that but it didnt fix my gpu problem sadly.
 I hope i can fix it with my new gpu.
My my other problem is that i cant use my wifi somehow. Shall i delete the kext?
Greets
delete AirportBrcmFixup.kext and try
Hi MaLd0n!
So for the WiFi it was just a bad card. Replaced it and it worked.
The mouse lag issue was caused by my iiyama display that didnt like the DisplayPort connection or DP 1.2, my new LG has FreeSync and 1.4 so this might have fixed the problem.
Now i installed my new GPU card and also a GB Titan Ridge 2.0.
Could you please create a new DSDT for me? ( Will this enable the THB card?)
Thanks very much!!
My setup:
Intel Core i9 9900K
Gigabyte RX5700 XT 8GB OC (new / was RX5500)
2x Corsair 16GB 3200MHz RAM
Gigabyte Titan Ridge 2.0 (new)
BCM94360CD WiFi / Bluetooth 4.0 Card
1TB Pioneer NVMe M.2 SSD
Running Catalina 10.15.4 / OpenCore 0.6.3
Edited by beatboi1
go to bios and check and save one ioreg
-Thunderbolt Configuration-
Security Level - No Security
GPIO3 Force Pwr - Enabled
  • Thanks 1
3 hours ago, beatboi1 said:
I used a hot plug SSDT to boot with the card in this RunMe, is that ok?
yes. use ssdt hotplug with dsdt
looks good. hotplug work?
  • Thanks 1
Okay, awesome. Yes hotplug works!
Thank you so much man! Your commitment is awesome and i really appreciate it!
beatboi
