I am attempting to get my Surface Pro 2 to run on Catalina but I'm thinking I might need some DSDT patches.
I'm new at hackintosh and I am getting close to getting everything working.
I have it booting off UEFI using clover for now. I had to use the included olarilla config2.plist to get it to boot. I tried to use the one config for my chipset but I kept getting a kernal panic for some reason
What doesn't work:
- Fans are running full speed (Seems to be running hot) Maybe I can optimize the cpu scaling / fan speed?
- en0 is not set as built in - I am using the dock's built in ethernet which shows up as usb ethernet connector (Attempting to get null ethernet ktext working rn)
- Some graphical glitches (Going to try to implement the Intel HD video patch)
- Audio is not working (May need the audio patch)
- Wi-Fi (I don't believe there is a driver available for surface pro 2 from my research) Not as important
- Poor performance
Attached is my dump
Send me MacBook-Pro.zip
Edited by Buffer Overflow
